Einleitung
Your Samsung Galaxy Note Edge's battery may be dead or damaged and in need of replacement. Be wary and cautious of batteries that are leaking or damaged. Before beginning the repair guide, ensure you have the proper replacement battery- a Lithium-Ion 3000 mAh battery.
Was du brauchst
Power down your device and make sure that it is turned off.
Place the phone with the screen facing down on a clean flat surface.
Use your Supdger to remove the back cover of the phone using notch located in the top left corner of the phone.
Remove battery by using your Supdger on the notch located directly underneath battery location.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
La batterie a une faible autonomie et se dégrade vite, en bombant souvent. Déjà 3 batteries remplacées sans succès. Que faire?
