Einleitung
If your device isn’t properly taking photos and video, the camera may be faulty. Use this guide to replace the front camera in your device.
Place your device face down on a clean surface.
Use a Spudger to remove the back cover using the notch at the top left.
Use a Spudger to remove the battery using the notch located underneath the battery.
Note: During the creation of this guide, we did not have access to a battery.
Use a Spudger to separate the camera's connector.
Use a Spudger to remove the camera from its slot.
