Zum Hauptinhalt wechseln
Samsung Galaxy Note Edge Volume Button Replacement
Was du brauchst
  1. Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: Schritt 1, Bild 1 von 2 Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: Schritt 1, Bild 2 von 2
    • Place your device flat down on a clean surface.
    • Use a Spudger to remove the back cover using the notch at the top left.
  2. Samsung Galaxy Note Edge Volume Button Replacement: Schritt 2, Bild 1 von 1
    • Use a Spudger to remove the battery using the notch located underneath the battery.
    • Note: During the creation of this guide, we did not have access to a battery.
  3. Samsung Galaxy Note Edge Volume Button Replacement: Schritt 3, Bild 1 von 1
    • Remove the stylus from its sheathe.
  4. Samsung Galaxy Note Edge Volume Button Replacement: Schritt 4, Bild 1 von 1
    • Use a Philips #000 Screwdriver to remove the fifteen 4mm screws.
  5. Samsung Galaxy Note Edge Volume Button Replacement: Schritt 5, Bild 1 von 1
    • Use a Spudger to remove the black chassis and expose the motherboard.
  6. Samsung Galaxy Note Edge Volume Button Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy Note Edge Volume Button Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy Note Edge Volume Button Replacement: Schritt 6, Bild 3 von 3
    • Use a Spudger to disconnect the following connections:
    • Connection 1
    • Connection 2
    • Connection 3
  7. Samsung Galaxy Note Edge Volume Button Replacement: Schritt 7, Bild 1 von 1
    • Remove the connection for the front camera.
  8. Samsung Galaxy Note Edge Volume Button Replacement: Schritt 8, Bild 1 von 3 Samsung Galaxy Note Edge Volume Button Replacement: Schritt 8, Bild 2 von 3 Samsung Galaxy Note Edge Volume Button Replacement: Schritt 8, Bild 3 von 3
    • Do not try to completely remove the motherboard until the final step.
    • Use a Spudger to gently lift the motherboard.
    • Remove the connection of the motherboard and the daughter board.
    • Remove the motherboard.
  9. Samsung Galaxy Note Edge Volume Button Replacement: Schritt 9, Bild 1 von 3 Samsung Galaxy Note Edge Volume Button Replacement: Schritt 9, Bild 2 von 3 Samsung Galaxy Note Edge Volume Button Replacement: Schritt 9, Bild 3 von 3
    • Remove the volume button panel.
    • Remove the volume button connection.
    • Remove the volume button entirely.
Abschluss
Lizzie Todd
301 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G1, Harley Spring 2019 Mitglied von IUPUI, Team S1-G1, Harley Spring 2019
IUPUI-HARLEY-S19S1G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 429
