Einleitung
If you are unable to adjust the volume on your device, the volume switch may be faulty. Use this guide to replace the volume button in your device.
Was du brauchst
Place your device flat down on a clean surface.
Use a Spudger to remove the back cover using the notch at the top left.
Use a Spudger to remove the battery using the notch located underneath the battery.
Use a Spudger to disconnect the following connections:
Connection 1
Connection 2
Connection 3
Use a Spudger to gently lift the motherboard.
Remove the connection of the motherboard and the daughter board.
Remove the motherboard.
Remove the volume button panel.
Remove the volume button connection.
Remove the volume button entirely.
