Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace the headphone jack and earpiece speaker assembly of your Samsung Galaxy Note.
  1. Grasp the cap of the stylus and remove it from its slot in the midframe. Grasp the cap of the stylus and remove it from its slot in the midframe.
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker. Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Lift and remove the rear case from the phone. Lift and remove the rear case from the phone.
    • Lift and remove the rear case from the phone.
  4. Insert your finger in the notch of the battery compartment. Press the battery toward the rear facing camera while pulling outward.
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click. After the click, release the card and it will pop out of its slot. For reassembly, push the microSD card into the slot until it clicks in place.
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Remove the microSD card from its slot in the midframe.
    • Remove the microSD card from its slot in the midframe.
  7. Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment. Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Slide the SIM card out the rest of the way with your thumb and remove it from the device. Slide the SIM card out the rest of the way with your thumb and remove it from the device.
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry. Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Slide the plastic opening tool down the seam. Slide the plastic opening tool down the seam. Slide the plastic opening tool down the seam.
    • Slide the plastic opening tool down the seam.
  12. Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly. Slide the opening tool along the top edge of the phone. Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Remove the midframe from the display assembly. Remove the midframe from the display assembly.
    • Remove the midframe from the display assembly.
  14. Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly cable connector.
  15. Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
    • Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
  16. Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket. Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket.
    • Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket.
  17. Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly connector.
    • Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly connector.
  18. Use the point of a spudger to pry the headphone jack out of its recess in the display assembly. Use the point of a spudger to pry the headphone jack out of its recess in the display assembly.
    • Use the point of a spudger to pry the headphone jack out of its recess in the display assembly.
  19. Use a pair of tweezers, or your fingers, to remove the headphone jack/earpiece speaker assembly from the display assembly.
    • Use a pair of tweezers, or your fingers, to remove the headphone jack/earpiece speaker assembly from the display assembly.
Abschluss
11 weitere Nutzer haben diese Anleitung absolviert.
Sam Goldheart
437.790 Reputation
547 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
137 Mitglieder
16.018 Anleitungen geschrieben
I'd recommend getting an Original part if possible, the knock off speaker has no metal casing where the original does.
John Cobra - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 20,067
