Zum Hauptinhalt wechseln
Samsung Galaxy Note Micro USB Port Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Samsung Galaxy Note Micro USB Port Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung Galaxy Note Micro USB Port Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung Galaxy Note Micro USB Port Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure the screen is face-down and the camera is opposite you.
    • Insert the flat end of a spudger into the phone's top right rectangular slot.
    • Use the spudger as a lever to pry open the back of the phone.
  2. Samsung Galaxy Note Micro USB Port Replacement: Schritt 2, Bild 1 von 1
    • With the spudger still inserted, carefully slide the spudger down the side of the phone.
    • Gently peel off the back cover with your hand.
  3. Samsung Galaxy Note Micro USB Port Replacement: Schritt 3, Bild 1 von 1
    • Place the spudger in the battery's bottom right slot.
    • Gently pry to remove the battery.
  4. Samsung Galaxy Note Micro USB Port Replacement, Midframe: Schritt 4, Bild 1 von 1
    • Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
  5. Samsung Galaxy Note Micro USB Port Replacement: Schritt 5, Bild 1 von 1
    • Remove the stylus from the bottom of the phone.
  6. Samsung Galaxy Note Micro USB Port Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy Note Micro USB Port Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy Note Micro USB Port Replacement: Schritt 6, Bild 3 von 3
    • Pry all the way around the sides with a plastic pry tool and gently pop off the midframe.
    • If the cover does not come off easily, continue to pry along the phone's perimeter.
    • This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
    • Separate the midframe from the phone. The midframe should now pull off easily.
  7. Samsung Galaxy Note Micro USB Port Replacement, Micro USB Port: Schritt 7, Bild 1 von 1
    • Turn the phone so the screen is on the table and the USB port is facing you.
    • Disconnect the orange ribbon near the bottom of the device using a spudger.
  8. Samsung Galaxy Note Micro USB Port Replacement: Schritt 8, Bild 1 von 1
    • Remove the three 3mm screws on the bottom of the device with a Phillips #00 screwdriver.
  9. Samsung Galaxy Note Micro USB Port Replacement: Schritt 9, Bild 1 von 1
    • Remove the black rectangular bracket imprinted with a "7" where you just removed the screws. The piece should pop off easily.
    • Disconnect the antenna (white wire) with a spudger by prying the metal part gently off.
  10. Samsung Galaxy Note Micro USB Port Replacement: Schritt 10, Bild 1 von 2 Samsung Galaxy Note Micro USB Port Replacement: Schritt 10, Bild 2 von 2
    • Slide spudger under the USB port and gently drag it left and right to remove the port from the phone.
    • Adhesive keeps the USB port from moving, so it might not pull up right away.
Abschluss
20 weitere Nutzer:innen haben diese Anleitung absolviert.
David Ritter
758 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 3-45, Amido Spring 2013 Mitglied von Cal Poly, Team 3-45, Amido Spring 2013
CPSU-AMIDO-S13S3G45
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 6,656
