Zum Hauptinhalt wechseln
Samsung Galaxy Note Pro 12.2 Audio Jack Replacement
Was du brauchst
  1. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement, Audio Jack: Schritt 1, Bild 1 von 1
    • Make sure that your device is powered off before starting your repair.
    • Carefully remove the back cover with the blue opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 3mm Phillips #00 screws securing in the white cover over the audio jack.
  3. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: Schritt 3, Bild 1 von 1
    • Remove the white cover over the audio jack with the plastic opening tool by pushing up on the black connecter.
  4. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: Schritt 4, Bild 2 von 2
    • Remove the two 3mm Phillips #00 screws over the silver cover.
    • The silver cover is attached to the whole audio jack; do not try to pull this away by itself.
  5. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: Schritt 5, Bild 2 von 2
    • Pop up the green connecter by gently pulling up.
  6. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: Schritt 6, Bild 2 von 2
    • Pull up on the circular amp with the spudger tool to release it from the device.
  7. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: Schritt 7, Bild 1 von 1
    • Remove the whole audio jack by pulling gently up on the copper piece.
    • This component is extremely fragile.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 680
