Einleitung
If you are having trouble with using your headphones, you may need to replace your audio jack. This guide will show you how to safely replace the audio jack in your device.
Was du brauchst
Remove the two 3mm Phillips #00 screws securing in the white cover over the audio jack.
Remove the white cover over the audio jack with the plastic opening tool by pushing up on the black connecter.
Pull up on the circular amp with the spudger tool to release it from the device.
