Einleitung
If your device is unable to read your SD card, you may need to replace your port. This guide will show you how to safely replace your SD port.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Pop open the orange wire tab connected to the SD port with the plastic opening tool.
Using the plastic end of the tweezers pop up the orange tab connecting the SD port to the device.
Fast fertig!
Abschluss
