Einleitung
If you are having trouble with the volume and quality of sound with your tablet you may need to replace your speakers. This guide will help you safely replace the speakers in your tablet.
Was du brauchst
Using the plastic opening tool, pop the black speaker up and away from the device.
Remove the two 3mm screws securing the white speaker with the Phillips #00 screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
