Zum Hauptinhalt wechseln
Samsung Galaxy Note Vibrator Replacement
Was du brauchst
  1. Samsung Galaxy Note Vibrator Replacement, Stylus: Schritt 1, Bild 1 von 2 Samsung Galaxy Note Vibrator Replacement, Stylus: Schritt 1, Bild 2 von 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung Galaxy Note Vibrator Replacement, Rear Case: Schritt 2, Bild 1 von 2 Samsung Galaxy Note Vibrator Replacement, Rear Case: Schritt 2, Bild 2 von 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
    Frag FixBot
  3. Samsung Galaxy Note Vibrator Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Note Vibrator Replacement: Schritt 3, Bild 2 von 2
    • Lift and remove the rear case from the phone.
    Frag FixBot
  4. Samsung Galaxy Note Vibrator Replacement, Battery: Schritt 4, Bild 1 von 2 Samsung Galaxy Note Vibrator Replacement, Battery: Schritt 4, Bild 2 von 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
    Frag FixBot
  5. Samsung Galaxy Note Vibrator Replacement, MicroSD Card: Schritt 5, Bild 1 von 3 Samsung Galaxy Note Vibrator Replacement, MicroSD Card: Schritt 5, Bild 2 von 3 Samsung Galaxy Note Vibrator Replacement, MicroSD Card: Schritt 5, Bild 3 von 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    Frag FixBot
  6. Samsung Galaxy Note Vibrator Replacement: Schritt 6, Bild 1 von 1
    • Remove the microSD card from its slot in the midframe.
    Frag FixBot
  7. Samsung Galaxy Note Vibrator Replacement, SIM Card: Schritt 7, Bild 1 von 2 Samsung Galaxy Note Vibrator Replacement, SIM Card: Schritt 7, Bild 2 von 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
    Frag FixBot
  8. Samsung Galaxy Note Vibrator Replacement: Schritt 8, Bild 1 von 2 Samsung Galaxy Note Vibrator Replacement: Schritt 8, Bild 2 von 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
    Frag FixBot
  9. Samsung Galaxy Note Vibrator Replacement, Midframe: Schritt 9, Bild 1 von 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
    Frag FixBot
  10. Samsung Galaxy Note Vibrator Replacement: Schritt 10, Bild 1 von 2 Samsung Galaxy Note Vibrator Replacement: Schritt 10, Bild 2 von 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
    Frag FixBot
  11. Samsung Galaxy Note Vibrator Replacement: Schritt 11, Bild 1 von 3 Samsung Galaxy Note Vibrator Replacement: Schritt 11, Bild 2 von 3 Samsung Galaxy Note Vibrator Replacement: Schritt 11, Bild 3 von 3
    • Slide the plastic opening tool down the seam.
    Frag FixBot
  12. Samsung Galaxy Note Vibrator Replacement: Schritt 12, Bild 1 von 3 Samsung Galaxy Note Vibrator Replacement: Schritt 12, Bild 2 von 3 Samsung Galaxy Note Vibrator Replacement: Schritt 12, Bild 3 von 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
    Frag FixBot
  13. Samsung Galaxy Note Vibrator Replacement: Schritt 13, Bild 1 von 2 Samsung Galaxy Note Vibrator Replacement: Schritt 13, Bild 2 von 2
    • Remove the midframe from the display assembly.
    Frag FixBot
  14. Samsung Galaxy Note Vibrator Replacement, Motherboard Assembly: Schritt 14, Bild 1 von 2 Samsung Galaxy Note Vibrator Replacement, Motherboard Assembly: Schritt 14, Bild 2 von 2
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
    Frag FixBot
  15. Samsung Galaxy Note Vibrator Replacement: Schritt 15, Bild 1 von 3 Samsung Galaxy Note Vibrator Replacement: Schritt 15, Bild 2 von 3 Samsung Galaxy Note Vibrator Replacement: Schritt 15, Bild 3 von 3
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
    Frag FixBot
  16. Samsung Galaxy Note Vibrator Replacement: Schritt 16, Bild 1 von 3 Samsung Galaxy Note Vibrator Replacement: Schritt 16, Bild 2 von 3 Samsung Galaxy Note Vibrator Replacement: Schritt 16, Bild 3 von 3
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
    Frag FixBot
  17. Samsung Galaxy Note Vibrator Replacement: Schritt 17, Bild 1 von 1
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
    Frag FixBot
  18. Samsung Galaxy Note Vibrator Replacement: Schritt 18, Bild 1 von 2 Samsung Galaxy Note Vibrator Replacement: Schritt 18, Bild 2 von 2
    • Remove the motherboard assembly from the display assembly.
    Frag FixBot
  19. Samsung Galaxy Note Vibrator Replacement, Vibrator: Schritt 19, Bild 1 von 3 Samsung Galaxy Note Vibrator Replacement, Vibrator: Schritt 19, Bild 2 von 3 Samsung Galaxy Note Vibrator Replacement, Vibrator: Schritt 19, Bild 3 von 3
    • Insert the tip of a spudger under the vibrator connector cable near the contacts then slide it toward the vibrator itself.
    Frag FixBot
  20. Samsung Galaxy Note Vibrator Replacement: Schritt 20, Bild 1 von 2 Samsung Galaxy Note Vibrator Replacement: Schritt 20, Bild 2 von 2
    • Insert the flat end of a spudger under the vibrator connector cable and pry it up from the adhesive.
    Frag FixBot
  21. Samsung Galaxy Note Vibrator Replacement: Schritt 21, Bild 1 von 1
    • Remove the vibrator from the display assembly.
    Frag FixBot
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Sam Goldheart
477.643 Reputation
538 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
27.514 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 54
Insgesamt: 6,616
