Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace the rear cover on your Samsung Galaxy Note10+.
  1. Completely power off your phone before you begin disassembly.
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible. If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover. Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive. Don't insert the opening pick more than halfway into the phone or you risk damaging internal components. Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Repeat the previous heating and cutting procedure for the remaining three sides of the phone. Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing. The rear cover will begin to separate from the phone as you finish all sides of the phone.
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
    • The rear cover will begin to separate from the phone as you finish all sides of the phone.
  5. Lift the rear cover straight up to remove it. Follow this guide to reinstall the rear cover and replace the adhesive.
    • Lift the rear cover straight up to remove it.
    • Follow this guide to reinstall the rear cover and replace the adhesive.
    • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
    • If you're using Tesa tape to reattach components, follow this guide.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
2 weitere Nutzer haben diese Anleitung absolviert.
Carsten Frauenheim
55.459 Reputation
293 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
140 Mitglieder
17.046 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 4
Letzten 7 Tage: 39
Letzten 30 Tage: 171
Insgesamt: 1,542
