Einleitung
The Samsung Galaxy Note 7 is a rather dangerous phone, but even if it's rare and borderline unusable, it still needs proper documentation and maintenance.
NOTE: This guide assumes that you have a replacement screen + midframe with the other non-motherboard parts (speakers, S-pen compartment, etc).
Was du brauchst
Apply heat to the back panel, use a guitar pick and suction cup to carefully remove the adhesive and remove the back panel.
Remove the screws holding the wireless charging and NFC cover in place using a 00 screwdriver, then lift it off.
Carefully disconnect and remove the battery by lifting up the connector with either your fingernail or the flat end of a plastic spudger.
Using the flat end of a plastic spudger, carefully remove and lift up every connector on the board.
Make sure to press them a little further upward using the spudger, or else they might end up blocking the motherboard from being lifted up, and can also get stuck underneath it during the reassembly process.
Using a plastic spudger, lift up the bottom part of the motherboard, then lift it up and out of the frame.
To reassemble the phone with the new screen + midframe, follow these steps in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
