Zum Hauptinhalt wechseln
Austausch des Touchscreens und des LCD Displays am Samsung Galaxy Note8
    • Schau das Video an.
Ziellinie
21 weitere Nutzer:innen haben diese Anleitung absolviert.
fr de
100%
VauWeh hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
ian mdx
8.968 Reputation
17 Anleitungen geschrieben
9 Kommentare
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
Andrew Gross - Antwort
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
Jack Donovan -
note8 siyah ekran bozuldu. fiyat nedir
yasin tufekci - Antwort
Mine is coming up saying Note Network found after completion of the repair any ideas?
James Turner - Antwort
Will the phone remain waterproof after this repair?
cj-dm - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 24,037
