Einleitung
This guide demonstrates how to remove and replace a cracked or otherwise non-functional screen on a Samsung Galaxy Player 5.0 in order to preserve the function of your device.
Werkzeuge
Ersatzteile
Remove the SD card before disassembling the device.
Use a screwdriver to remove the screw near the SD card.
Go to the bottom of the device and remove the white caps covering the screws.
After removing the caps, use a screwdriver to remove the screws at the bottom of the device. Set aside.
Starting from the bottom, use a pry tool to separate the front housing cover from the back cover.
Pull the front and back cover halves apart completely.
Use a screwdriver to remove the screw pictured.
Use a prying tool to remove the headphone jack.
Set both carefully aside.
Disconnect the LCD flex cable.
Use a screwdriver to remove six screws pictured.
Hold the PCD unit and lift it up.
Switch out the old digitizer for the new one. Reconnect all the cables and screws in the reverse sequence.
Ein weiterer Nutzer hat diese Anleitung absolviert.
