Einleitung
You may need to replace your battery if your current battery is damaged, or is not attaining power from an outlet. No background information is required.
Was du brauchst
Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
I just replaced the battery about a month ago after turning phone off and the turned back on it stuck on screen with samsung and the other lights stayed on
Mine doing the same
