Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Using this guide you will replace the camera lens fixing hardware related camera issues such as scratches or cracks.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Remove the (6) 4mm screws using a Phillips #00 screwdriver.
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Replace the secondary rear panel which has the camera lens attached.
    • Replace the secondary rear panel which has the camera lens attached.
Abschluss
Ricardo Zuloaga
525 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 17-6, Blackwell Fall 2016 Mitglied von USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 183
