Einleitung
By following this guide you should be able to fix issues with an unresponsive or cracked screen.
Was du brauchst
Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
Using the black spudger, carefully unhinge and pry the secondary rear panel , which houses the camera lens and speaker.
Using a spudger, carefully unhinge the gray shield plate by lifting upwards on the right side.
Eine weitere Person hat diese Anleitung absolviert.
