Zum Hauptinhalt wechseln
Samsung Galaxy R Front Facing Camera Replacement
Was du brauchst
  1. Samsung Galaxy R Front Facing Camera Replacement, Rear Case: Schritt 1, Bild 1 von 3 Samsung Galaxy R Front Facing Camera Replacement, Rear Case: Schritt 1, Bild 2 von 3 Samsung Galaxy R Front Facing Camera Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung Galaxy R Front Facing Camera Replacement, Battery: Schritt 2, Bild 1 von 3 Samsung Galaxy R Front Facing Camera Replacement, Battery: Schritt 2, Bild 2 von 3 Samsung Galaxy R Front Facing Camera Replacement, Battery: Schritt 2, Bild 3 von 3
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
    Frag FixBot
  3. Samsung Galaxy R Front Facing Camera Replacement, Remove screws: Schritt 3, Bild 1 von 2 Samsung Galaxy R Front Facing Camera Replacement, Remove screws: Schritt 3, Bild 2 von 2
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
    Frag FixBot
  4. Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: Schritt 4, Bild 1 von 3 Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: Schritt 4, Bild 2 von 3 Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: Schritt 4, Bild 3 von 3
    • The front facing camera is located in the top right corner of the back of the phone.
    • To remove the camera, gently pull until it detaches from the motherboard.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Clemson, Team 3-3, Benson Fall 2014 Mitglied von Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 38
Insgesamt: 709
