Was du brauchst
Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone
Remove the battery and use a small Phillips head screwdriver to remove the marked up screws
Use a flat tool to pry the two plastic cases apart
The latches are very strong, so don't be afraid to use force
Locate the missing button slot
Place in replacement button, and close the plastic housing around it
The button should be fully functional now, repeat past steps to reassemble the phone
Gently remove the two ribbon cables as shown.
Connect the new screen to the main motherboard just as the same way they were connected.
Be careful not to crimp or bend the ribbon cables, as this will ruin the replacement.
Repeat the steps in reverse order to reassemble the phone.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
