Einleitung
This shows you how to remove or replace the frame in a Samsung Galaxy S Blaze phone.
Was du brauchst
Hold phone to see notch on the side of the back plate.
Apply pressure to the back plate to remove the back plate.
Using your index finger, pull the top of the battery. Then pull the battery towards you.
The battery will fall out easily.
Remove the eight 4 mm screws from the frame using a Phillips #00 screwdriver.
Insert the blue plastic opening tool between the frame and the device.
Push down on the tool to raise up the frame from the device.
Work around the device until the frame is completely off.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
