Was du brauchst
Use a Phillips head screwdriver size 00.
Remove the 4mm screws from the frame. The screws can be removed in any order.
Use the blue plastic opening tool to remove the frame from the device.
Work around the device with the opening tool until the frame is completely off the device.
Unlatch the first 3 ribbon cable connectors with the blue plastic opening tool.
Unlatch the final ribbon cable connector with the blue plastic opening tool.
Remove the motherboard from the device.
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 weitere Nutzer:innen haben diese Anleitung absolviert.
