Zum Hauptinhalt wechseln
Samsung Galaxy S Blaze Motherboard Replacement
Was du brauchst
  1. Samsung Galaxy S Blaze Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Remove the battery cover from the device.
  2. Samsung Galaxy S Blaze Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery from the device.
  3. Samsung Galaxy S Blaze Motherboard Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy S Blaze Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame. The screws can be removed in any order.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Use the blue plastic opening tool to remove the frame from the device.
    • Work around the device with the opening tool until the frame is completely off the device.
    • You may need to use some force to pry the frame off of the device.
  5. Samsung Galaxy S Blaze Motherboard Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy S Blaze Motherboard Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy S Blaze Motherboard Replacement: Schritt 5, Bild 3 von 3
    • The motherboard is held onto the device by 4 ribbon cable connectors.
    • The first 3 ribbon cable connectors are on the same side.
    • Unlatch the first 3 ribbon cable connectors with the blue plastic opening tool.
  6. Samsung Galaxy S Blaze Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Turn the motherboard over to reveal the last ribbon cable connector.
    • Unlatch the final ribbon cable connector with the blue plastic opening tool.
    • Remove the motherboard from the device.
Abschluss
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 weitere Personen haben diese Anleitung absolviert.
Rene Bolanos
435 Reputation
2 Anleitungen geschrieben
Sam Houston State, Team 11-1, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 11-1, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 877
