Einleitung
This guide will show how to properly replace the SD card slot cover on a Samsung Galaxy S Blaze 4G. The replacement of the SD card slot cover is an easy process with no surprises. You will need to be careful while taking out the screws, the screws will damage easily.
Was du brauchst
Use a Phillips #00 screwdriver to remove the eight 4 mm screws from the device frame.
Use the blue plastic opening tool to gently pry the frame off the phone.
Work around the phone with the blue plastic opening tool until the frame is off.
Unhook the tab of the SD card slot cover from the frame of the device.
This is what the tab of the SD card slot cover looks like.
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 weitere Nutzer:innen haben diese Anleitung absolviert.
