Zum Hauptinhalt wechseln
Samsung Galaxy S Blaze Volume Rocker Replacement
Was du brauchst
  1. Samsung Galaxy S Blaze Volume Rocker  Replacement, Volume Rocker: Schritt 1, Bild 1 von 1
    • Start by removing the back plate to expose the battery by pulling the back and front plates apart.
  2. Samsung Galaxy S Blaze Volume Rocker  Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery from the device and set aside.
  3. Samsung Galaxy S Blaze Volume Rocker  Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy S Blaze Volume Rocker  Replacement: Schritt 3, Bild 2 von 2
    • Using a Phillips Head Screwdriver size 00. Remove all eight 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Volume Rocker  Replacement: Schritt 4, Bild 1 von 1
    • Remove the frame from the phone by prying it off with the iFixit blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Samsung Galaxy S Blaze Volume Rocker  Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy S Blaze Volume Rocker  Replacement: Schritt 5, Bild 2 von 2
    • The volume rocker is held into the frame by two small prongs.
    • Carefully unhook the prongs from the frame by pulling to the side and remove the volume rocker.
    • The prongs on the volume rocker look like this.
Abschluss
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
Eine weitere Person hat diese Anleitung absolviert.
Jake Best
261 Reputation
2 Anleitungen geschrieben
Sam Houston State, Team 11-1, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 11-1, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 401
