Zum Hauptinhalt wechseln
Samsung Galaxy S II Front Glass/Digitizer Replacement
Was du brauchst
Einführungsvideo
  1. Samsung Galaxy S II Front Glass/Digitizer Replacement, Front Glass and Digitizer: Schritt 1, Bild 1 von 2 Samsung Galaxy S II Front Glass/Digitizer Replacement, Front Glass and Digitizer: Schritt 1, Bild 2 von 2
    • We have a Samsung Galaxy S II with broken screen.
    Frag FixBot
  2. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 2, Bild 3 von 3
    • Remove your battery, the SIM card and the SD card.
    • Remove the 7 screws highlighted in red.
    Frag FixBot
  3. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 3, Bild 3 von 3
    • Use a plastic tool to remove the rear housing.
    Frag FixBot
  4. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 4, Bild 2 von 2
    • The mother board is held by 2x screws. Remove them.
    Frag FixBot
  5. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 5, Bild 3 von 3
    • Remove the cables that are highlighted in red, before continuing to the screen.
    Frag FixBot
  6. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 6, Bild 3 von 3
    • Release the side buttons. The arrow will point you to where they are.
    Frag FixBot
  7. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 7, Bild 1 von 2 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 7, Bild 2 von 2
    • Careful release the motherboard from it's housing.
    Frag FixBot
  8. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 8, Bild 1 von 2 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 8, Bild 2 von 2
    • At this moment if you have touch screen with LCD and frame like spare part you are ready for replacing.
    • We will continue with disassembling LCD and Touch from the frame. Now preheat it before removing!
    • Use a hot air to soften the adhesive enough to remove the glass.
    Frag FixBot
  9. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 9, Bild 1 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 9, Bild 2 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 9, Bild 3 von 3
    • With a cutter, make a room for a plastic tool, then continue with separating the Touchscreen & LCD Display from the frame.
    Frag FixBot
  10. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 10, Bild 1 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 10, Bild 2 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 10, Bild 3 von 3
    • Be careful with the menu buttons flex cable in the bottom side of the touchscreen. You must release it before separating the digitizer from the frame.
    Frag FixBot
  11. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 11, Bild 1 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 11, Bild 2 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 11, Bild 3 von 3
    • Now, use a suction tool to remove the screen from it's housing. Be careful when doing this, to prevent possible injury.
    Frag FixBot
  12. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 12, Bild 1 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 12, Bild 2 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 12, Bild 3 von 3
    • Clean the frame from the remains of tape.
    Frag FixBot
  13. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 13, Bild 1 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 13, Bild 2 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 13, Bild 3 von 3
    • Test the new spare part before reassembling.
    Frag FixBot
  14. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 14, Bild 1 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 14, Bild 2 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 14, Bild 3 von 3
    • Install the LCD&Digitiser on it's housing.
    • Many times the spare parts come without adhesive tape. In this situation you'll need to install double sided adhesive tape yourself. Also you can easy find adhesive sticker exactly for the model.
    Frag FixBot
  15. Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 15, Bild 1 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 15, Bild 2 von 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: Schritt 15, Bild 3 von 3
    • To reassemble your device, follow these instructions in reverse order.
    Frag FixBot
Abschluss
32 weitere Personen haben diese Anleitung absolviert.
ZFix
197.189 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
333 Mitglieder
1.479 Anleitungen geschrieben
9 Kommentare zur Anleitung
I attempted to replace the display glass alone on a Virgin Mobile Galaxy SII, and was unsuccessful. Removing the Glass from the Digitizer proved to be extremely difficult. It seems as if the Virgin Mobile version of the SII is not meant for repair, so easily.
Edward Weissbard - Antwort Teilen
Yes, removing the glass is very difficult and you must have some experience from before.
ZFix - Antwort Teilen
To moderators: please un-archive this guide: there's no replacement or "updated version of the guide" among the current guides.
yurkennis - Antwort Teilen
To moderators :
please there is a photo of a babe in the video tutorial and in the photo tutorial, not for children.
Frederic Morelli - Antwort Teilen
how much the cost in replacement display with fame.....samsung galaxy s2
Bhola Shrestha - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 27
Letzte 30 Tage: 107
Insgesamt: 99,871
