Zum Hauptinhalt wechseln
Einleitung
Before any work can be done, on the inside of the phone, we need an access point. This is achieved by removing the rear cover of the phone. This plate protects the battery, media card, and SIM card from being exposed or damaged from common use of the phone.
Werkzeuge
Keine Werkzeuge angegeben.
  1. To remove the rear cover, locate the tab indicated by the red outline. Using your fingernail, gently pry the rear cover. Using your fingernail, gently pry the rear cover.
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
Abschluss
Joshua King
1.330 Reputation
9 Anleitungen geschrieben
Clemson, Team 1-5, Benson Spring 2014 Mitglied von Clemson, Team 1-5, Benson Spring 2014
CLEM-BENSON-S14S1G5
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 732
