Zum Hauptinhalt wechseln
Samsung Galaxy S III Motherboard Assembly Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Samsung Galaxy S III Motherboard Assembly Replacement, Motherboard Assembly: Schritt 1, Bild 1 von 1
    • Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
    • Do not try to remove the front-facing camera just yet. Its cable is still routed beneath the motherboard assembly to the ambient light sensor.
  2. Samsung Galaxy S III Motherboard Assembly Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy S III Motherboard Assembly Replacement: Schritt 2, Bild 2 von 2
    • Disconnect the digitizer cable by gently prying its connector up from its socket on the motherboard.
  3. Samsung Galaxy S III Motherboard Assembly Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy S III Motherboard Assembly Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the display data cable from the motherboard.
  4. Samsung Galaxy S III Motherboard Assembly Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy S III Motherboard Assembly Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy S III Motherboard Assembly Replacement: Schritt 4, Bild 3 von 3
    • Pry the Wi-Fi antenna cable connector up from its socket on the motherboard.
    • Gently move the cable out of the way of the motherboard.
  5. Samsung Galaxy S III Motherboard Assembly Replacement: Schritt 5, Bild 1 von 1
    • Remove the single 3.0 mm Phillips screw securing the motherboard to the front panel assembly.
  6. Samsung Galaxy S III Motherboard Assembly Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy S III Motherboard Assembly Replacement: Schritt 6, Bild 2 von 2
    • Carefully lift the bottom of the motherboard assembly away from the front panel assembly.
    • Remove the motherboard assembly from the front panel assembly, minding any cables that may snag on it.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 146
