Zum Hauptinhalt wechseln
Samsung Galaxy S III Plastic Midframe Replacement
Was du brauchst
  1. Samsung Galaxy S III Plastic Midframe Replacement, Rear Case: Schritt 1, Bild 1 von 2 Samsung Galaxy S III Plastic Midframe Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Plastic Midframe Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy S III Plastic Midframe Replacement: Schritt 2, Bild 2 von 2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Plastic Midframe Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy S III Plastic Midframe Replacement: Schritt 3, Bild 2 von 2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Plastic Midframe Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy S III Plastic Midframe Replacement: Schritt 4, Bild 2 von 2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Plastic Midframe Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy S III Plastic Midframe Replacement: Schritt 5, Bild 2 von 2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III Plastic Midframe Replacement, Battery: Schritt 6, Bild 1 von 2 Samsung Galaxy S III Plastic Midframe Replacement, Battery: Schritt 6, Bild 2 von 2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Plastic Midframe Replacement: Schritt 7, Bild 1 von 2 Samsung Galaxy S III Plastic Midframe Replacement: Schritt 7, Bild 2 von 2
    • Remove the battery.
  8. Samsung Galaxy S III Plastic Midframe Replacement, SIM Card: Schritt 8, Bild 1 von 3 Samsung Galaxy S III Plastic Midframe Replacement, SIM Card: Schritt 8, Bild 2 von 3 Samsung Galaxy S III Plastic Midframe Replacement, SIM Card: Schritt 8, Bild 3 von 3
    • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the SIM card into the slot until it clicks in place.
  9. Samsung Galaxy S III Plastic Midframe Replacement: Schritt 9, Bild 1 von 3 Samsung Galaxy S III Plastic Midframe Replacement: Schritt 9, Bild 2 von 3 Samsung Galaxy S III Plastic Midframe Replacement: Schritt 9, Bild 3 von 3
    • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
    • Grasp and remove the SIM card away from the phone.
  10. Samsung Galaxy S III Plastic Midframe Replacement, microSD Card: Schritt 10, Bild 1 von 3 Samsung Galaxy S III Plastic Midframe Replacement, microSD Card: Schritt 10, Bild 2 von 3 Samsung Galaxy S III Plastic Midframe Replacement, microSD Card: Schritt 10, Bild 3 von 3
    • Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  11. Samsung Galaxy S III Plastic Midframe Replacement: Schritt 11, Bild 1 von 2 Samsung Galaxy S III Plastic Midframe Replacement: Schritt 11, Bild 2 von 2
    • Use your thumb to slide the microSD card out of the slot.
    • Remove the microSD card from the phone.
  12. Samsung Galaxy S III Plastic Midframe Replacement, Plastic Midframe: Schritt 12, Bild 1 von 1
    • Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
  13. Samsung Galaxy S III Plastic Midframe Replacement: Schritt 13, Bild 1 von 2 Samsung Galaxy S III Plastic Midframe Replacement: Schritt 13, Bild 2 von 2
    • Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
    • The midframe lightly snaps in place, and can be removed with very little force.
Abschluss
38 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 41,054
