Zum Hauptinhalt wechseln
Samsung Galaxy S Vibrant Loud Speaker Replacement
Was du brauchst
  1. Samsung Galaxy S Vibrant Loud Speaker Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung Galaxy S Vibrant Loud Speaker Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung Galaxy S Vibrant Loud Speaker Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
    Frag FixBot
  2. Samsung Galaxy S Vibrant Loud Speaker Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy S Vibrant Loud Speaker Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
    Frag FixBot
  3. Samsung Galaxy S Vibrant Loud Speaker Replacement, Midframe: Schritt 3, Bild 1 von 1
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
    Frag FixBot
  4. Samsung Galaxy S Vibrant Loud Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
    Frag FixBot
  5. Samsung Galaxy S Vibrant Loud Speaker Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy S Vibrant Loud Speaker Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy S Vibrant Loud Speaker Replacement: Schritt 5, Bild 3 von 3
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
    Frag FixBot
  6. Samsung Galaxy S Vibrant Loud Speaker Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy S Vibrant Loud Speaker Replacement: Schritt 6, Bild 2 von 2
    • Slide the SD card out of its slot.
    Frag FixBot
  7. Samsung Galaxy S Vibrant Loud Speaker Replacement, Loud Speaker: Schritt 7, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Phillips #00 Screwdriver
    $5.49
    • Locate the seven screws on the plastic casing.
    • Using the Phillips #00 Screwdriver, remove all seven screws.
    • Be careful not to lose any of these small screws.
    Frag FixBot
  8. Samsung Galaxy S Vibrant Loud Speaker Replacement: Schritt 8, Bild 1 von 1
    • Once all seven screws have been removed, use the Plastic Opening Tools to gently release the plastic snaps around the seam of the black casing.
    • Be careful not to break any of the plastic snaps.
    Frag FixBot
  9. Samsung Galaxy S Vibrant Loud Speaker Replacement: Schritt 9, Bild 1 von 1
    • After all the plastics snaps have been released, the black plastic casing will come off easily.
    • Locate the speaker.
    Frag FixBot
  10. Samsung Galaxy S Vibrant Loud Speaker Replacement: Schritt 10, Bild 1 von 1
    • Using the Plastic Opening Tools, carefully lift the golden-brown clamp holding down the speaker's ribbon cable.
    • Remove the speaker by gently pulling it.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 18-37, Regan Winter 2013 Mitglied von Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 37
Insgesamt: 3,360
