Zum Hauptinhalt wechseln
Samsung Galaxy S Vibrant Midframe Replacement
Was du brauchst
    1. Samsung Galaxy S Vibrant Midframe Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung Galaxy S Vibrant Midframe Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung Galaxy S Vibrant Midframe Replacement, Battery: Schritt 1, Bild 3 von 3
      • Locate the small slit on the bottom edge of the device between the back and front cases.
      • Pop the back case off by inserting your finger and pulling the case away from the phone.
      • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
      Frag FixBot
      Kommentar hinzufügen
    2. Samsung Galaxy S Vibrant Midframe Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy S Vibrant Midframe Replacement: Schritt 2, Bild 2 von 2
      • Remove the battery by pushing the bottom edge of the battery up and away from the phone
      • If you would prefer, you may use the Plastic Opening Tools for this step as well.
      Frag FixBot
    1. Samsung Galaxy S Vibrant Midframe Replacement, Midframe: Schritt 3, Bild 1 von 1
      • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
      Frag FixBot
    2. Samsung Galaxy S Vibrant Midframe Replacement: Schritt 4, Bild 1 von 1
      • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
      Frag FixBot
    3. Samsung Galaxy S Vibrant Midframe Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy S Vibrant Midframe Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy S Vibrant Midframe Replacement: Schritt 5, Bild 3 von 3
      • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
      • Work carefully, and disengage all of the clips before removing the midframe.
      • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
      Frag FixBot
    4. Samsung Galaxy S Vibrant Midframe Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy S Vibrant Midframe Replacement: Schritt 6, Bild 2 von 2
      • Slide the SD card out of its slot.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 18-37, Regan Winter 2013 Mitglied von Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Mitglieder
84 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 42
Insgesamt: 2,007
