Einleitung
Use this guide to replace the motherboard in your Samsung Galaxy S4.
  1. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
    • Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe.
    • Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
    • Slide the opening tool along the seam, separating the plastic clips as you go.
    • Be very gentle whilst prying, and pry only enough to separate the plastic clips—there are several thin points in the midframe bezel that may crack if you bend them too much.
    • Continue prying around the corner of the phone.
    • Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
    • Again, pry around the corner, to the power button side.
    • Slide the opening tool along the seam.
    • Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
    • At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
    • Remove the midframe from the display assembly.
    • Use the flat end of a spudger to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
    • Using tweezers, or your fingers, slide the rear-facing camera out of its notch in the motherboard.
Abschluss
139 weitere Nutzer haben diese Anleitung absolviert.
Sam Lionheart
Mitglied seit 18.10.2012
350.879 Reputation
535 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
108 Mitglieder
7.543 Anleitungen geschrieben
where can one buy a replacement motherboard?
Joe - Antwort
I have a M919 with dead motherboard. Can i swap with an i9505motherboard insted? will all the components work on this new motherboard?
Augusto Nascimento - Antwort
Hi I have a question. I have Galaxy S4 but The screen just broke and my sister give her galaxy s4 can i just change the motherboard to my phone or need to change the other parts too? Please help my i dont want to change all the parts if i dont need to!?
Ray Flores - Antwort
Mboard only.
djweijers1997 -
I wanted to know if I could swap my broken verizon gs4 motherboard with a us cellular gs4 motherboard
devynrice93 - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 18
Letzte 7 Tage: 130
Letzte 30 Tage: 519
Insgesamt: 187,851
