Einleitung
To replace the 16 megapixel rear-camera, follow the steps to remove all previous components required. Take full precaution when operating tools such as heat guns, as they can cause potential health hazards.
Was du brauchst
Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Use a heat gun at an approximate distance of 2-3 inches from the phone to apply heat to the phone and loosen up the adhesive in the display.
Starting from the upper left corner, insert a guitar pick in between the display and the phone case.
Use the pick to pry the sides and lower part of the display by sliding the pick through the phone.
Use the sharp tip of a guitar pick to lift the front panel assembly cable connector straight up off its socket on the motherboard.
Safely remove the front panel assembly from phone.
Use a Phillips 0 screwdriver to remove all 12 Phillips #0 screws.
Push upward from the back side your phone (where the battery should go) to pop out the large gray piece.
You should now have two different pieces. To continue we will only use the piece with the motherboard (Shown on the right side of the picture).
Use your finger or a plastic opening tool to disconnect the rear-facing camera from the motherboard.
7 weitere Personen haben diese Anleitung absolviert.
6 Kommentare
Where did you purchase the replacement camera/lens?
Same here. I only need the lens cover.
On ebay sales
What if I'm just replacing the glass and not the entire camera?
Did you get an answer already? Or did you find a solution in the mean while? My cameraglass is also broken...
