Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
  1. Remove back cover.
    • Remove back cover.
  2. Remove battery. If you have SIM card and SD card in, remove them by the way.
    • Remove battery. If you have SIM card and SD card in, remove them by the way.
  3. Open this cover and release the home button flex connector. Open this cover and release the home button flex connector.
    • Open this cover and release the home button flex connector.
  4. Heat the screen, cut the sticker under it and release the screen connector. Please be careful with the screen flex when sliding to cut the sticker. Heat the screen, cut the sticker under it and release the screen connector. Please be careful with the screen flex when sliding to cut the sticker. Heat the screen, cut the sticker under it and release the screen connector. Please be careful with the screen flex when sliding to cut the sticker.
    • Heat the screen, cut the sticker under it and release the screen connector. Please be careful with the screen flex when sliding to cut the sticker.
  5. Remove the LCD screen from rear case. Remove the LCD screen from rear case.
    • Remove the LCD screen from rear case.
  6. Remove all the screws. Remove all the screws.
    • Remove all the screws.
  7. Get loosen the touch keys from adhesive, and then push the mid-plate out from the middle housing. Get loosen the touch keys from adhesive, and then push the mid-plate out from the middle housing.
    • Get loosen the touch keys from adhesive, and then push the mid-plate out from the middle housing.
  8. Twist off these two screws and remove the whole motherboard assembly. Twist off these two screws and remove the whole motherboard assembly.
    • Twist off these two screws and remove the whole motherboard assembly.
  9. Release the connector,loose the assembly from adhesive and remove it finally. Release the connector,loose the assembly from adhesive and remove it finally. Release the connector,loose the assembly from adhesive and remove it finally.
    • Release the connector,loose the assembly from adhesive and remove it finally.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Sophia
43.261 Reputation
62 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 4,886
