Einleitung
This guide will show you how to replace the front-facing camera on this device. As with the back-facing camera, this replacement will require most of the phone to be taken apart beforehand.
Was du brauchst
Remove the back casing of the phone using the notch located at the top.
Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
