Einleitung
If your Samsung Galaxy S6 Active isn’t producing clear audio through headphones or auxiliary speakers, use this guide to replace the headphone jack.
Before using this guide, inspect the headphone jack for any debris that may be affecting the sound quality of the phone. Typically, a small buildup dust can be cause of the headphone jack not functioning properly. Be sure to use an ESD-safe brush or a small dust blower to remove this buildup of dust. Test a few sets of headphones or auxiliary cords with your phone to confirm that the faulty part is coming from the Samsung Galaxy S6 Active’s headphone jack.
Before beginning, make sure to completely power off your phone and disconnect it from any external power source.
Was du brauchst
Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
Pry open the tray to get it out of the socket.
Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
Slide the plastic opening tool around the screen, prying the display gently away from the body
Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
The battery will be on the back side of this frame.
Insert a plastic opening tool on the side of the frame and pull out the battery.
Use a plastic tool to undo all the connections in the motherboard.
Insert the flats end of the spudger below the motherboard and twist it to pry the board up.
Insert a spudger at the bottom, between the headphone jack connection and the rear case, to loosen the headphone jack.
Use a plastic opening tool to pry the headphone jack up, and remove the headphone jack from the rear case.
