Zum Hauptinhalt wechseln
Samsung Galaxy S6 Active Power Button Replacement
Was du brauchst
  1. Samsung Galaxy S6 Active Power Button Replacement, SIM Card: Schritt 1, Bild 1 von 2 Samsung Galaxy S6 Active Power Button Replacement, SIM Card: Schritt 1, Bild 2 von 2
    • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
    • Pry open the tray to get it out of the socket.
  2. Samsung Galaxy S6 Active Power Button Replacement: Schritt 2, Bild 1 von 1
    • Remove the SIM tray with SIM card from the phone.
  3. Samsung Galaxy S6 Active Power Button Replacement, Display Assembly: Schritt 3, Bild 1 von 3 Samsung Galaxy S6 Active Power Button Replacement, Display Assembly: Schritt 3, Bild 2 von 3 Samsung Galaxy S6 Active Power Button Replacement, Display Assembly: Schritt 3, Bild 3 von 3
    • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
    • If using an iOpener, heat it in a microwave for thirty seconds.
  4. Samsung Galaxy S6 Active Power Button Replacement: Schritt 4, Bild 1 von 1
    • Attach a suction cup to the lower half of the screen.
  5. Samsung Galaxy S6 Active Power Button Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy S6 Active Power Button Replacement: Schritt 5, Bild 2 von 2
    • Using the suction cup, pull gently the lower half of the panel.
    • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
  6. Samsung Galaxy S6 Active Power Button Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy S6 Active Power Button Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy S6 Active Power Button Replacement: Schritt 6, Bild 3 von 3
    • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
    • Slide the plastic opening tool around the screen, prying the display gently away from the body
  7. Samsung Galaxy S6 Active Power Button Replacement: Schritt 7, Bild 1 von 1
    • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
    • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
  8. Samsung Galaxy S6 Active Power Button Replacement: Schritt 8, Bild 1 von 3 Samsung Galaxy S6 Active Power Button Replacement: Schritt 8, Bild 2 von 3 Samsung Galaxy S6 Active Power Button Replacement: Schritt 8, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
  9. Samsung Galaxy S6 Active Power Button Replacement: Schritt 9, Bild 1 von 1
    • Undo the screen connection with a plastic tool.
  10. Samsung Galaxy S6 Active Power Button Replacement: Schritt 10, Bild 1 von 1
    • Remove the display assembly (LCD and Digitizer).
  11. Samsung Galaxy S6 Active Power Button Replacement, Battery: Schritt 11, Bild 1 von 2 Samsung Galaxy S6 Active Power Button Replacement, Battery: Schritt 11, Bild 2 von 2
    • Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
  12. Samsung Galaxy S6 Active Power Button Replacement: Schritt 12, Bild 1 von 1
    • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
    • You will hear the clips start undoing themselves.
  13. Samsung Galaxy S6 Active Power Button Replacement: Schritt 13, Bild 1 von 2 Samsung Galaxy S6 Active Power Button Replacement: Schritt 13, Bild 2 von 2
    • Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
    • The battery will be on the back side of this frame.
  14. Samsung Galaxy S6 Active Power Button Replacement: Schritt 14, Bild 1 von 1
    • Insert a plastic opening tool on the side of the frame and pull out the battery.
  15. Samsung Galaxy S6 Active Power Button Replacement: Schritt 15, Bild 1 von 2 Samsung Galaxy S6 Active Power Button Replacement: Schritt 15, Bild 2 von 2
    • Remove the battery from the frame.
  16. Samsung Galaxy S6 Active Power Button Replacement, Motherboard: Schritt 16, Bild 1 von 3 Samsung Galaxy S6 Active Power Button Replacement, Motherboard: Schritt 16, Bild 2 von 3 Samsung Galaxy S6 Active Power Button Replacement, Motherboard: Schritt 16, Bild 3 von 3
    • Use a plastic tool to undo all the connections in the motherboard.
    • There are three connections that have to be removed.
  17. Samsung Galaxy S6 Active Power Button Replacement: Schritt 17, Bild 1 von 2 Samsung Galaxy S6 Active Power Button Replacement: Schritt 17, Bild 2 von 2
    • Insert the flats end of the spudger below the motherboard and twist it to pry the board up.
  18. Samsung Galaxy S6 Active Power Button Replacement: Schritt 18, Bild 1 von 1
    • Remove the motherboard from the rear case.
  19. Samsung Galaxy S6 Active Power Button Replacement, Power Button: Schritt 19, Bild 1 von 1
    • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate it from the plastic cover.
  20. Samsung Galaxy S6 Active Power Button Replacement: Schritt 20, Bild 1 von 2 Samsung Galaxy S6 Active Power Button Replacement: Schritt 20, Bild 2 von 2
    • Once you see a large enough gap, insert a plastic tool between the frame and the plastic cover and slide it around the phone to separate both components.
  21. Samsung Galaxy S6 Active Power Button Replacement: Schritt 21, Bild 1 von 1
    • Remove the plastic cover from the phone.
  22. Samsung Galaxy S6 Active Power Button Replacement: Schritt 22, Bild 1 von 1
    • Insert a plastic tool between the frame of the phone and the back cover at the top left corner.
  23. Samsung Galaxy S6 Active Power Button Replacement: Schritt 23, Bild 1 von 1
    • Leave the plastic tool inside in order to access the power button connection.
  24. Samsung Galaxy S6 Active Power Button Replacement: Schritt 24, Bild 1 von 2 Samsung Galaxy S6 Active Power Button Replacement: Schritt 24, Bild 2 von 2
    Kaufen
    • Use the tweezers to pry up the power button ribbon cable until the only thing attached to the frame are the contacts.
    • Pulling too hard can rip off the ribbon cable. Make sure not to pull the entire body together.
  25. Samsung Galaxy S6 Active Power Button Replacement: Schritt 25, Bild 1 von 2 Samsung Galaxy S6 Active Power Button Replacement: Schritt 25, Bild 2 von 2
    • Insert the tweezers under the contact points to undo the connection.
  26. Samsung Galaxy S6 Active Power Button Replacement: Schritt 26, Bild 1 von 1
    • Use the tweezers to remove the power button bracket.
  27. Samsung Galaxy S6 Active Power Button Replacement: Schritt 27, Bild 1 von 1
    • The power button is located on the plastic cover.
    • Use the tweezers to push the power button out of the frame.
  28. Samsung Galaxy S6 Active Power Button Replacement: Schritt 28, Bild 1 von 1
    • Remove the power button from the frame.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Lucia Valbuena
2.412 Reputation
8 Anleitungen geschrieben
USF Tampa, Team 1-5, Sullivan Spring 2017 Mitglied von USF Tampa, Team 1-5, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G5
3 Mitglieder
25 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 1,246
