Zum Hauptinhalt wechseln
Samsung Galaxy S7 Active Disassembly
Was du brauchst
  1. Samsung Galaxy S7 Active Disassembly, Samsung Galaxy S7 Active Disassembly: Schritt 1, Bild 1 von 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Disassembly: Schritt 2, Bild 1 von 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Disassembly: Schritt 3, Bild 1 von 2 Samsung Galaxy S7 Active Disassembly: Schritt 3, Bild 2 von 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Disassembly: Schritt 4, Bild 1 von 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S18-G1, Livingston Spring 2018 Mitglied von Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Mitglieder
15 Anleitungen geschrieben
Ein Kommentar
What about fixing the phone sure you can take it apart but what about fixing
Robert Ydstie - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 23
Insgesamt: 4,327
