Zum Hauptinhalt wechseln
Samsung Galaxy S7 Active Screen Replacement
Was du brauchst
  1. Samsung Galaxy S7 Active Screen Replacement, Samsung Galaxy S7 Active Disassembly: Schritt 1, Bild 1 von 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Screen Replacement: Schritt 2, Bild 1 von 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Screen Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy S7 Active Screen Replacement: Schritt 3, Bild 2 von 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Screen Replacement: Schritt 4, Bild 1 von 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Screen Replacement, Screen: Schritt 5, Bild 1 von 3 Samsung Galaxy S7 Active Screen Replacement, Screen: Schritt 5, Bild 2 von 3 Samsung Galaxy S7 Active Screen Replacement, Screen: Schritt 5, Bild 3 von 3
    • Use the tweezers to disconnect the screen from the phone by detaching the connection.
  6. Samsung Galaxy S7 Active Screen Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy S7 Active Screen Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy S7 Active Screen Replacement: Schritt 6, Bild 3 von 3
    • Clean the rest of the adhesive left on the phone by scraping it off with a metal tool.
    • Apply rubbing alcohol on the adhesive to make sure phone is free of any adhesive. Do this by applying some rubbing alcohol onto a napkin.
    • Lightly proceed to clean the phone with that napkin.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S18-G1, Livingston Spring 2018 Mitglied von Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Mitglieder
15 Anleitungen geschrieben
3 Kommentare
Do you know where i can find a replacement screen assembly, cant find one anywhere
Sam Ellis - Antwort
I bought a digitizer with fog and polarizer and a new front glass, it came with the loca. What else do I need to make the complete LCD screen assembly?
Michael Shep - Antwort
The instructions are excessively brief. The photos are insufficient to convey the details of this operation. Attempted and damaged my phone.
RAC - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 9,050
