Einleitung
Dein Samsung Galaxy s7 Home Button funktioniert nicht? Hier ist die Lösung! Wie repariere ich den Samsung Galaxy Home Button des Samsung Galaxy S7!
Was du brauchst
Videoanleitungen
Um das Gerät wieder zusammenzusetzen, führe die Anweisungen in umgekehrter Reihenfolge aus.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
5 Kommentare
Hi,
Recently screen replaced with new homebutton - now fingerprint sensor is only giving error, any way to fix this?
Phone is rooted and has cust.firmware installed.
Try to fix :
factory defaults
reboots
cleared cache
Thanks for your reply!
Patrick Pieck - Antwort
Thanks for you info.
www.movilone.es
MovilOne - Antwort
hi finger scanner is not working but home button is work please suggest me
Shamim Akhtar - Antwort
its cause the fingerprint sensor is synced with your logic board, you would have to write a script for it to work… which in that case would make you the first one to do so
Eric Touzin -
I need to replace the board of charger port with the module antenne, so I need to disamble the screen and don't know a what temperature I have to put the blower to not damage the LCD screen.
Joe Morel - Antwort
