Zum Hauptinhalt wechseln
Samsung Galaxy S7 Home Button austauschen
Was du brauchst
Videoanleitungen
Abschluss
Um das Gerät wieder zusammenzusetzen, führe die Anweisungen in umgekehrter Reihenfolge aus.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
en de
100%
Hier starten ›
MovilOne
2.480 Reputation
14 Anleitungen geschrieben
5 Kommentare
Hi,
Recently screen replaced with new homebutton - now fingerprint sensor is only giving error, any way to fix this?
Phone is rooted and has cust.firmware installed.
Try to fix :
factory defaults
reboots
cleared cache
Thanks for your reply!
Patrick Pieck - Antwort
Thanks for you info.
www.movilone.es
MovilOne - Antwort
hi finger scanner is not working but home button is work please suggest me
Shamim Akhtar - Antwort
its cause the fingerprint sensor is synced with your logic board, you would have to write a script for it to work… which in that case would make you the first one to do so
Eric Touzin -
I need to replace the board of charger port with the module antenne, so I need to disamble the screen and don't know a what temperature I have to put the blower to not damage the LCD screen.
Joe Morel - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 17,821
