Zum Hauptinhalt wechseln
Samsung Galaxy S8 Plus Motherboard Replacement
Was du brauchst
    • Step by step tutorial about dismantling the logic board from Galaxy S8+. If you need more information ask them in the comments!
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Sander
38.237 Reputation
202 Anleitungen geschrieben
3 Kommentare
How do you then fix the imei to match the back of the phone and to work with the plan it was on when broken; having to register/activate a new device for a motherboard repair is bull$][!+, and doesn't take care of the problem for the customer.
chrisjwellnitz - Antwort
Hello, The connector from the battery to the motherboard has been damaged. Due to water getting in there’s been corrosion on the connectors which has eaten away on 2 of the capacitors there down to the silicon. Is there anyway to fix this? Perhaps any way to add material back or make some kind of jumper? I doubt I can get a replacement motherboard, but if you know if this can be done that would be great.
Ggarcia - Antwort
..does this correct a problem with the SIM card holder or is that a separate board in the phone?
Sigmund -
Sigmund - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 83
Insgesamt: 10,948
