Einleitung
If your back cover is broken, this is the guide for you. Please be careful and have packing tape handy: this job can be a little risky.
Be forewarned - if you remove or replace the back cover, your device will lose its waterproof capabilities unless you also replace the waterproof seal.
Was du brauchst
Heat the iOpener in the microwave for 30-60 seconds.
Apply the iOpener to the backside edge and let it sit for 2-3 minutes.
Press the suction handle firmly on to the back cover.
Insert an opening pick between the back cover and the device's body while pulling upwards on the suction handle.
Apply more opening picks to the edges of the phone, heating the other sides as needed.
Use the iFixit opening tool to separate the back cover from the rest of the device.
