Zum Hauptinhalt wechseln
Samsung Galaxy S9 SIM Card or MicroSD Card Replacement
  1. Samsung Galaxy S9 SIM Card or MicroSD Card Replacement, SIM Card or MicroSD Card: Schritt 1, Bild 1 von 2 Samsung Galaxy S9 SIM Card or MicroSD Card Replacement, SIM Card or MicroSD Card: Schritt 1, Bild 2 von 2
    • The SIM card tray's ejection hole and the microphone hole look very similar, be very careful not to insert the tool inside the microphone hole or you might damage the microphone.
    • Insert a SIM card ejector or anything as thin inside the SIM tray ejection hole, on the top of the phone above the camera.
    • Press in to eject the tray.
  2. Samsung Galaxy S9 SIM Card or MicroSD Card Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy S9 SIM Card or MicroSD Card Replacement: Schritt 2, Bild 2 von 2
    • Grab the part of the tray that came out and pull it out of the phone.
    • The SIM/SD cards in the tray can easily fall off so be careful and make sure not to loose them.
    • When putting the tray back in place check that your cards are well positioned and fit in the tray or they might not work correctly, or worse, be broken when you put everything back inside.
Abschluss
To reassemble your device, follow the instructions backwards.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
fr en
100%
Hier starten ›
cPix
3.995 Reputation
8 Anleitungen geschrieben
Ein Kommentar
Super tuto. Merci Cpix, j'ai bien suivi votre tutoriel et maintenant, je peux passer des appels.
Ace Ace - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 41
Letzte 30 Tage: 215
Insgesamt: 8,840
