Einleitung
Using these steps, you can replace the volume button on your Galaxy SIII Mini VE.
  1. Flip your phone so you are facing the back. Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing. Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
    • Flip your phone so you are facing the back.
    • Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
  2. Use your finger or an opening tool to pry the battery out of the phone. Use your finger or an opening tool to pry the battery out of the phone.
    • Use your finger or an opening tool to pry the battery out of the phone.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
    • Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
  5. Using an opening tool, gently separate the plastic framing from the phone. Using an opening tool, gently separate the plastic framing from the phone.
    • Using an opening tool, gently separate the plastic framing from the phone.
  6. Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger. Next, use the spudger and tweezers to remove the speaker at the top of the phone. Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
    • Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger.
    • Next, use the spudger and tweezers to remove the speaker at the top of the phone.
    • Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
    • Detach this connection using the spudger.
  7. Locate the volume button. Using the tweezers, life the volume button up and away from the phone.
    • Locate the volume button.
    • Using the tweezers, life the volume button up and away from the phone.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Megan
1.152 Reputation
6 Anleitungen geschrieben
Michigan Tech, Team 1-8, Lauer Fall 2014 Mitglied von Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
3 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 740
