Einleitung
For the Cricket Samsung Galaxy Sol, the battery needed is a Samsung battery that is a 3.8V (voltage), 2100mAh (capacity), and made out of Lithium Ion. Some of the reasons that you would need to replace the battery would be an overheated battery or a faulty battery which could be a manufacturing error. When replacing the battery, it's important to use the proper tools, otherwise you could damage the phone. One tool that could be helpful is a plastic spudger to lift the battery and the phone back case.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  3. Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 19
All Time: 335
