Zum Hauptinhalt wechseln
Samsung Galaxy Sol Front Camera Replacement
Was du brauchst
  1. Samsung Galaxy Sol Front Camera  Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Front Camera  Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Front Camera  Replacement, Front Camera: Schritt 3, Bild 1 von 1
    • Remove all ten 0.4 mm screws with a Phillips #00 screw bit. After this, you will be able to lift up and remove the grey plastic piece.
  4. Samsung Galaxy Sol Front Camera  Replacement: Schritt 4, Bild 1 von 1
    • Remove the front camera at the top left of the phone be carefully removing it with tweezers.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 439
