Einleitung
How to Replace the Memory card. Without the Memory card the user could not keep any media on the phone. Memory cards can become corrupted from virus or bugs or sometimes they are filled up to the max with media and a larger one needs to be put in pace. This guide shows you had to replace it if needed in a few easy steps.
Was du brauchst
Place phone firmly between both hands with one hand flat on the back of the phone and pop off the back cover
Once rear cover is off use small pastic spudger to lift battery out of the phone
After following the steps for battery replacement, the SD memory card is going to be able slide right out of this slot for replacement.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
