Zum Hauptinhalt wechseln
Samsung Galaxy Stardust Battery Replacement
Was du brauchst
  1. Samsung Galaxy Stardust Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Galaxy Stardust Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Hold down the power button located on the right side of the phone.
    • After five seconds, the screen will display three different options. Select the "power off" option.
  2. Samsung Galaxy Stardust Battery Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Stardust Battery Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Stardust Battery Replacement: Schritt 2, Bild 3 von 3
    • Place your finger or opening tool in the hole on the side of the phone.
    • Carefully pull the back casing away from the phone while keeping the phone stable.
  3. Samsung Galaxy Stardust Battery Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Stardust Battery Replacement: Schritt 3, Bild 2 von 2
    • Place both the phone and the phone casing next to each other with the battery facing upwards.
    • Carefully lift the battery from the indent above the battery, then place the battery next to the phone.
  4. Samsung Galaxy Stardust Battery Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Stardust Battery Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Stardust Battery Replacement: Schritt 4, Bild 3 von 3
    • Take your new battery and look for the plus and minus signs on the bottom of the battery.
    • Line up the signs to the three strips on the bottom of the phone.
    • Carefully place the battery in until it is secure inside the phone.
  5. Samsung Galaxy Stardust Battery Replacement: Schritt 5, Bild 1 von 1
    • Take the back of the phone and line up the circular hole to the camera.
    • Apply force to the back of the phone with your hand, until the back case snaps onto the phone and is secure.
Ziellinie
Alan Kwong
121 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G11, Sinclaire Spring 2021 Mitglied von UMass Dartmouth, Team S1-G11, Sinclaire Spring 2021
UMASSD-SINCLAIRE-S21S1G11
1 Mitglied
2 Kommentare
bom dia como concertar o samsung A32
camargowil - Antwort
bom dia podem me mandar ,para mim e outros armenque o esquema eletrico do samsung A32=SM-A32 5M/DS
como desmontar e se possivel o esquema eletrico.
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 51
Insgesamt: 2,525
