Zum Hauptinhalt wechseln
Samsung Galaxy Tab 2 7.0 Camera Replacement
Was du brauchst
  1. Samsung Galaxy Tab 2 7.0 Camera Replacement, Camera: Schritt 1, Bild 1 von 1
    • Using a nylon spudger or a flat plastic opening tool, pry open the back of the device.
    • It is easiest to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Camera Replacement: Schritt 2, Bild 1 von 1
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the battery on the device.
    • Remove the battery, and set it aside.
  3. Samsung Galaxy Tab 2 7.0 Camera Replacement: Schritt 3, Bild 1 von 1
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  4. Samsung Galaxy Tab 2 7.0 Camera Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Tab 2 7.0 Camera Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Tab 2 7.0 Camera Replacement: Schritt 4, Bild 3 von 3
    • Locate the 8 flex cables attached to the motherboard.
    • Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp objects have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  5. Samsung Galaxy Tab 2 7.0 Camera Replacement: Schritt 5, Bild 1 von 1
    • Locate the camera towards the top of the device.
    • Use a nylon spudger to gently lift the camera and remove it from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Katija Tarailo
460 Reputation
3 Anleitungen geschrieben
IUPUI, Team S3-G1, Harley Spring 2017 Mitglied von IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 662
